Resolved! Solved
Samsung Flow !πŸ™„πŸ™„ Problem !!!
(Topic created on: 04-24-2021 05:18 PM)
Strangeneria
Galaxy M
I am not able to cast hotstar video on PC through Samsung flow !
Any solution ?πŸ€”
πŸ™„πŸ™„πŸ™„πŸ™„
If not then any other solution for this ???πŸ€”
3 Solutions
Galaxy M
Use smartview . I changed my name and Monster reloaded 😎
Not applicable
Galaxy M
Ur wish
But Google home no need any USB
Smart view disabled by Samsung so I can't view through inbuld smart view so I using it
Make sure ur devices are connected to network I think that's why it doesn't shows cast option
Sidhabhi
β˜…β˜…
Galaxy M
Smart view will help..
46 Comments
Not applicable
Galaxy M
Use Google home
Strangeneria
Galaxy M
Means ?πŸ€”πŸ€”.... I heard it firstime πŸ˜…πŸ˜…
Well this problem is same with jio tv also πŸ™
Strangeneria
Galaxy M
Bro how to link it with gooogle home ?πŸ€”πŸ€”πŸ€”
Not applicable
Galaxy M
See
Strangeneria
Galaxy M
Can i connect with usb ?
Not applicable
Galaxy M
Ur wish
Strangeneria
Galaxy M
Ok !... I will try
Not applicable
Galaxy M
I use It for smart view
Not applicable
Galaxy M
After Android 11 update smart view not working so I connected my TV to this app and I viewing
