HisHolyness
Galaxy M
Yesterday I updated my Samsung galaxy m01.After that I am experiencing audio problem as the quality of sound is not good enough as I am using earphones while watching YouTube video. Plz help
5 Comments
drjeneth
Beginner Level 4
Galaxy M
Me too having the same problem after os update
cs_member8
Galaxy M
Dear Samsung Member,
We would request you to register your concern in Samsung Members Application. So, that our concern team gets back to you as soon as possible.
Please follow this path to register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
Note. please attach the error log file within 15 minutes of the error occurred.
krishbarnwal
Galaxy M
Found a little help. Try setting the limit for audio over headset from volume bar> 3dot> settings icon> 3 dot > set audio limit and fix one value which you use. Done try playing the music at lesser volm than the limit. Please don't expect it to do wonders. It doesnt help much but patch updates are a little far now. I didn't find it out someone on YouTube found it out. Well share with other m01 users if you have time. Thanks.
AgentDarkFury
Galaxy M
Won't help
AgentDarkFury
Galaxy M
They've just released a patch for this issue
Install it and you're good to go!Screenshot_20210521-113333_Software update_10338.jpg
