M35 battery draining issue
(Topic created on: 11-29-2024 10:42 PM)
MithunSarkarUGB
Galaxy M
After the November security patch update, the battery of my m35 is draining very fast than before. Please fix this problem by giving a software update samsung india. 🙏
2 Comments
goodthings
Galaxy M
cs_member10
Galaxy M
Dear Samsung Member,
As per your concern, we would request you kindly perform the following steps to resolve your issue by the given links. We are taking your valuable feedback regarding drain issue.
● Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
→ Update the software if available: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-smartphone-how-to-update-software/
→ You can reset your device by following the steps.
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send.)
