M35 battery drain issue
(Topic created on: 10-30-2024 07:43 PM)
golusolanki
Galaxy M
I purchased recently new samsung galaxy m35 but there is a problem in this is that my phone's battery is draining very very quickly. not excepted from samsung. Worst experience ever from samsung. Please fix this problem
10 Comments
MrSurendra
Galaxy M
I'm also getting heating issue while charging and battery draining issues
golusolanki
Galaxy M
Apke pass bhi m35 hi h kya
MrSurendra
Galaxy M
Han
golusolanki
Galaxy M
Ha bhai mere pass bhi m35 hi h. Tumhare isme m35 me kitni kya battery issue hora h kitni der khatam hori battery kuch idea? Or charging me problem hora h kya ?
himansh11
Galaxy M
Your device is new give it some time to learn your usage pattern about 15 to 20 days.
Your can also enable battery saver and disable turn off 5g in battery saver option.
Thank-you.
If you like please accept as a solution it might help others.follow 3 dots on on right corner of comment
golusolanki
Galaxy M
But why I use in restrictions. They didn't give any statement about how to use your phone,what to use, when to use.....
Aniket_Rana
Beginner Level 4
Galaxy M
1 Bhai auto update apps ko off kro
2 Brightness ko 70/80% rakho
3 Location/ wifi / Bluetooth/ off rkho
4 Jarurt padne pd net use kro wrna usko bnd kr do
5 Dark wallpaper use kro
6 Screen time 15 pr rakho
7 Dark mode on rakho always
8 Apps ko manually update kro
LloydJ
Galaxy M
Yes, most of the people dont know how to use phone properly will end up draining the battery quickly. I do follow the above mentioned points and my phone m35 give 9-10 hours of screen on time [sot]
cs_member10
Galaxy M
Dear Samsung Member,
As per your concern, we want to inform you that when initially using the device, battery consumption may be rapid due to learning battery usage patterns and application of performance optimization. It will stabilize after a certain period, but if still facing issues, kindly perform the following steps to resolve your issue.
● Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
If the issue still occurs, please visit the service centre for a physical inspection of your device. You can locate your nearest service centre with this given link: https://www.samsung.com/in/support/service-center/
