05-24-2020 01:11 PM (Last edited 05-24-2020 01:12 PM ) in
Galaxy M
Above you can see I've got 22% battery left. The sum of battery usage of the apps listed was around 40%. What about the missing 38%? What used 38% of the battery? This is from a 2 day old m31. I thought the battery life would be awesome but boy :(. Please help.
P.S.: I switch off all unnecessary features and services like wifi, data, auto-sync off when not in use.
- Tags:
- battery drain
- m31
05-24-2020 01:14 PM in
Galaxy M- Mark as New
05-24-2020 01:20 PM in
Galaxy MSorry I'm shifting from oneplus. I really don't know how Samsung works. I could almost add up my battery usage of my op5 even after 2-3 years.
05-24-2020 02:15 PM in
05-24-2020 05:50 PM (Last edited 05-24-2020 05:54 PM ) in
Galaxy MAnd second thing is go to Device Care then go to battery.
After that App power management and in that select Sleeping apps and select all the applications except Google.
Because if you add Google in that list it will consume more amount of battery.
At last i would like to say that let me know if this thing works for you.
05-24-2020 11:24 PM in
Galaxy MAlright. Did as you said. Left google(app), Grammarly, nova launcher and WhatsApp out of the sleeping apps list. I'll let you know how it goes in a couple of days.
05-25-2020 08:02 PM in
Galaxy MIt will definitely give you improvement in battery backup
05-27-2020 09:42 PM in
Galaxy MDear Samsung Member,
Please be assured and to resolve "Battery drainage" issue kindly follow the given below steps:
1)Battery optimization:-Settings>Select Device Maintenance/Device Care>Optimize>Optimize all options like Battery, Storage and Memory
2) Close background running apps:-Tap on recent key and close the background running application.
For more information on battery drainage please click on the link below:
http://www.samsung.com/in/support/skp/faq/1101689
If the issue still persist, kindly register your concern in Samsung Members app (Samsung Members app > Get help > Feedback > Error report/ask question).
Note: Please send device log files within 15 minutes of issue occurrence along with the exact issue details.
