arvi77099
pure apps sleeping mode me rahkar bhi battery kuch din se jaldi drain ho rahi..plz give some options.
4 Comments
MissonChoudhurY
first you setting your adaptive brightness and off your extra features like always on display ..regular full your charge and do not use less than 20%
rajkm008
Try these things to save your device battery
1. Settings >developer option >background process limit >choose no background process
2. Disable auto sync
3. optimise your device often using with device care app
4. on device care app >battery >3vertical dots >settings > put unused apps to sleep
5.Disable always on the display >if u don't use,
6. On the device care app>battery >disable background process which apps consumes most the battery
7. Turn of Gps, Bluetooth when not in use
doing this things can may help your device battery last longer
Not applicable
Clear the cache partition if you didn't and do some of the basic settings like keeping apps to sleep, restricting background data etc.
You can check this out.
https://r2.community.samsung.com/t5/Galaxy-M/Tips-to-improve-battery-life/td-p/5039156
cs-member13
Dear Samsung Member,
We apologize for the inconvenience caused to you. To resolve battery issue kindly follow the below given step:-
- Battery optimization:- Settings > Select Device Maintenance/Device Care>Optimize>Optimize all options like Battery, Storage and Memory
For more information on battery drainage please click on the link below:-
http://www.samsung.com/in/support/skp/faq/1101689
If the issue still persist, kindly register your concern in Samsung Members app (Samsung Members app > Get help > Feedback > Error report/ask question). Kindly send us the screenshot (which apps are consuming most of the battery).
Note: Please send device log files within 15 minutes of issue occurrence along with the exact issue details.
