Google and camera light sensor have major battery drain issue ,
(Topic created on: 02-28-2021 08:43 AM)
NitinNara
Galaxy M
I have samsung m31s smarphone it has some battery by Google and camera light sensor , how can it be resolve , even i put google in sleeping apps , thereafter it drain 10% of 6000mah battery , camera light sensor also consume 10% battery . They both run in background nearly 20hrs.
7 Comments
Galaxy M
camera light sensor is for adaptive brightness, Google is just being Google I usually keep all google stuff unless very necessary in deep sleep
Nick95
Galaxy M
RGB light sensor is a tiny sensor which is used for automatic brightness. It should not have caused this much drain as it's power usage is miniscule(will not cause even 1% even if continously used for 48 hours). It seems like some other problem. Sometimes what is shown in battery usage are not correct. better to restart phone. 99% of battery drain due to youtube , Google, instagram, careerwill and chrome app. Neglect light sensor as it is inaccurate reading.
RufusM31s
Expert Level 4
Galaxy M
For Google, just restart ur phone. I'm using the same phone as u are, and I faced the exact same issue. Restarting saved me that time...
Ehsank
Galaxy M
camera light sensor is not an issue only thing is you can see it on battery uses so many other sensor is also consuming battery but you can't see it on battery uses but anyway if you don't want then have to disable adaptive brightness/ face unlock
Ehsank
Galaxy M
and for battery which consuming by Google or other apps so as far as i know one of the main reasons of battery drain is background activity,
even you close apps but they uses ur battery and running in background unnecessary, see image(1) and read the statement.
2nd due to huge notification options.
for e.g ; Google has huge notification which we don't need at all see image(2) just scroll up and down and check how many notification it does have.
So do these settings to stop, which consume battery unnecessarily.
1. Settings>>Connection>more connections settings> disable nearby device settings
2. Settings>>Location>improve accuracy >disable
A. Wifi scanning
B. Bluetooth scanning .
Ehsank
Galaxy M
Besides above settings do some more settings to save more battery life and observe for next 1-2 days, it will give a noticeable difference
And enable these 2 options.
A. Adaptive battery
B. Put Unused Apps to Sleep.
FOR ANDROID 11;
A. DEVICE CARE > Battery>Background Uses Limit > Put Unused App to Sleep
B. Device care>click on 3dot at top right corner>automation>adaptive power saving
C. Device Care > Battery> More Battery Settings>Adaptive Battery
4. Long press on each app specially 3rd party(LIKE FACEBOOK, YOUTUBE) and rarely used apps and also ON "GOOGLE APP" as well, then click on>app info (ibutton> then go to these 3 options below on by one
5. Go to settings> privacy > permission manager > location> and check which app have accessing your location all the time and if not using that apps then deny access or set as " allowed only while in use"
6.  Go to settings > Google > on device sharing> check which 3rd party apps present there for e.g. if you use paytm , paytm will  shared data to show recommendation and suggestion which also cause battery drain
7.  Go to settings > account and backup> account > checkwhich app syncing automatically there and if any app which not necessary to auto sync then click on it and disable sync.
8. Go to settings >apps>search "weather" >click on settings icon right side > change "auto refresh" settings as per your requirements and disable some unnecessary reminder. ( due to auto refresh it continuously consuming battery)
10. Settings>>Google >click on 3dot at right top corner>usage and diagnostics >off this option.
Samsung_Support1
Galaxy M
Dear Samsung Member,
To resolve your device battery drain issue please visit this link: https://www.samsung.com/in/support/mobile-devices/samsung-mobile-battery-drain-issue/
For further assistance, register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
