Galaxy M31 4G Network/Battery/Camera Problems
(Topic created on: 11-25-2020 09:48 PM)
Raajonali
Galaxy M
We are using Galaxy M31. we are family of M31 but satisfaction is lower than expected. Please Samsung send network issue fix update .
🔺 Problem is 4G connection not stable
 4G network signal showing 30/40% . My others phone Oppo & Vivo working fine it's 85/90% strong signal with network speed. (same operators & same area)
🔺 Camera is fine but when using it, my became sexy & increase it's hotness . (Temperature high)
🔺 Battery 6000 mh but not satisfied because it's look like I'm using 4500/5000 mh
4 Comments
sagar214
Galaxy M
facing same network problem , report to Samsung
GoTo2234
Galaxy M
For signal strength I would suggest - Check the SAR values of other phones. As Samsung always ensures users safety first.
Laxman52892
Galaxy M
download and install samsung band selection app and follow instructions
https://youtu.be/7_9E9b6OpUU
cs-member13
Expert Level 4
Galaxy M
Dear Samsung Member,
Please be assured and to resolve "network" issue please follow below given step:
>>Check device in safe mode:- Power off the device > Press and hold the Power key for one or two seconds to turn on the device > When the Samsung logo appears, press and hold the Volume down key.
To exit safe mode: Restart your device.
To resolve "heating" issue kindly follow the given link:- https://www.samsung.com/in/support/mobile-devices/why-the-heating-issue-occurs-in-mobile-device/
And to resolve "Battery drainage" issue kindly follow the given linkhttp://www.samsung.com/in/support/skp/faq/1101689
If the issue still persist, kindly register your concern in Samsung Members app (Samsung Members app > Get help > Feedback > Error report)along with screenshots, short videos and error log file, so that we can assist you accordingly.
Note: Please send device log files within 15 minutes of issue occurrence along with the exact issue details.
