10-15-2020 06:15 PM in
Galaxy MSolved! Go to Solution.
3 Solutions
10-15-2020 06:55 PM (Last edited 10-15-2020 06:57 PM ) in
Galaxy M1. Connection>more connections settings> disable nearby device settings
2. Location>improve accuracy >disable
A. Wifi scanning
B. Bluetooth scanning .
And enable these 2 options.
A. Adaptive battery
B. Put Unused Apps to Sleep.
4. Long press on each app specially 3rd party(LIKE FACEBOOK, INSTA,YOUTUBE) and rarely used apps and also ON "GOOGLE APP" as well, then click on>app info> then go to these 3 options below on by one
5. Go to settings >apps>search "weather" >click on settings icon right side > change "auto refresh" settings as per your requirements and disable some unnecessary reminder. ( due to auto refresh it continuously consuming battery?)
6. If you use Facebook frequently then disable "auto play video"
7. Google >click on 3dot>usage and diagnostics >off this option
10-15-2020 07:26 PM in
Galaxy M1. Unpair all Bluetooth devices which were connected earlier
Again turn on Bluetooth> Scan> Tap on the Bluetooth device
If not worked then ;
2. Please follow these instructions here > Settings > Apps > Show System Apps > Bluetooth Share / Bluetooth Test > Storage > Clear cache/data.
After even not worked then try below steps
3. Reset network settings >Settings>General Management>Reset >Reset network settings)
10-15-2020 07:27 PM in
Galaxy M- Mark as New
10-15-2020 06:54 PM (Last edited 10-15-2020 06:59 PM ) in
Galaxy M2nd due to huge notification enable.
for e.g ; Google has huge notification which we don't need at all see image just scroll down image and check how many notification it does have.
So do these settings to stop, which consume unnecessarily.
A. Wifi scanning
A. Wifi scanning
A. Adaptive battery
10-15-2020 07:34 PM in
10-17-2020 11:53 AM in
Galaxy MDear Samsung Member,
To resolve your device battery drain issue please visit this link: https://www.samsung.com/in/support/mobile-devices/samsung-mobile-battery-drain-issue/
For further assistance, register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
