Highlighted
NEW PHONE USING 20 DAYS BATTERY DRAIN ISSUE OCCURRED PLEASE FIX THIS ERROR
4 Comments
Highlighted
did you updated your software ever by mobile data or wifi after purchase?
Highlighted
Expert Level 4
SoT you get?
Highlighted
have u done these settings?
1. Connection>more connections settings> disable nearby device settings
2. Location>improve accuracy >disable
A. Wifi scanning
B. Bluetooth scanning .
3. Google >click on 3dot>usage and diagnostics >off this option
4. developer option >background limit>no background processes.
5. Long press on each app specially 3rd party and rarely used app>app info>
6. Device care>battery >select "optimised and adaptive power saving.
Highlighted
Dear Samsung Member,
To resolve "Battery drainage" issue kindly follow the given below steps:
1)Battery optimization:-Settings>Select Device Maintenance/Device Care>Optimize>Optimize all options like Battery, Storage and Memory
For more information on battery drainage please click on the link below:
http://www.samsung.com/in/support/skp/faq/1101689
If the issue still persist, kindly register your concern in Samsung Members app (Samsung Members app > Get help > Feedback > Error report/ask question) along with Video or Screen-shots(which application taking most of the battery). This will help us to further investigate and resolve your concern."
Note: Please send device log files within 15 minutes of issue occurrence along with the exact issue details.
