FACING PROBLEM WITH USING GAME PLUGINS FOR GALAXY M21 AND WILL IT GET ONEUI 2.1?
(Topic created on: 07-19-2020 02:49 AM)
AshikAbdullah
Galaxy M
I AM FACING PROBLEM WHILE INSTALLING "GAME PLUGINS". THE GALAXY STORE SAYS THAT THIS APPLICATION IS NOT COMPATIBLE WITH THIS DEVICE. HOW CAN I USE IT FOR MY #GALAXY M21
Whether Samsung will release One UI2.1 update for Samsung M21. IS SAMSUNG GALAXY M21 GET  THE ONE UI2.1 UPDATE OR DIRECTLYGET THE ONE UI 3.0 AFTER IT'S RELEASE.
5 Comments
Galaxy M
Bro, its clearly showing that game plug-in which you are downloading is not compatible with your device..so try some apk files and check if it works or not.Most probably its device compatibility issue..
AshikAbdullah
Galaxy M
I was tried to install the apk one. But that can't be install. It is failed to install several time.
Galaxy M
it says app not installed
Galaxy M
May be device compatibility issue
XxAlphaxX
Galaxy M
hi,can u please tell me how to unpin the fps meter from perf z in game plugins, I accidentally pinned by holding the fps meter and i can't unpin it,please tell with screenshots
