Extreme Battery drain : After UI 8 update : M35
(Topic created on: 10-17-2025 08:57 AM)
Nealesh
Galaxy M
This is to be bring in notice the phone battery drains fast while using phone and when at night sleep time till morning it drains by 6 to 7 percent. Where it was upto 2 percent before the update. Request Samsung team to look into these major issues on prior and release the solutions. As battery is the main concern to me.
Hope the other M35 users noticed the same??
8 Comments
sammyooo
Galaxy M
I am also concerned with this
jhuku
Galaxy M
No problem on this side, moreover battery performance has improved a lot
Roshxn208
Galaxy M
Mere toh Kuch Jada hu Bettery drain ho rhai 10% 6mit Screen time Dikha rha hai 😳
goodthings
Galaxy M
goodthings
Galaxy M
You're welcome to here.
ashish112
Galaxy M
Clear case and data in settings one ui home everything will be fine ❤
bhavint
Galaxy M
The phone has become almost perfect after the one ui 8 update
cs_member10
Galaxy M
Dear Samsung member,
3. Check device network fluctuation. Avoid usage in areas with low network/fluctuation.
9. Update software: Go to Settings > Software update > Download and install > Check for software update > If Software update available > Download > Downloading updates > Install now
10. Reset the device:
IMPORTANT:
• If you do not remember it, then reset (Forgot password) your google account.
• For this:
If the issue still persists, after performing all troubleshooting steps, would request you to please visit the service center. Below is the link to find nearest service center
http://www.samsung.com/in/support/servicelocation/
