Display and Battery Problem
(Topic created on: 10-07-2020 03:55 PM)
MindblowingMilan
Galaxy M
When I'm using Adaptive brightness on then display is flickering or low and hight brightness automatically even not displacement any direction on the screen. Please solve in  next update.
And also battery is not 7000mah battery bcz I'm using 5000mah battery mobile previously. So same service to this mobile. I think it is used 6000mah battery not 7000mah battery.
5 Comments
TimonN
Expert Level 3
Galaxy M
Please file complaint against Samsung if you think and can prove that they have used 6000 mAh battery instead of 7000 mAh.
Ehsank
Galaxy M
to improve battery performance do these settings if you not done yet
and observe for next 1-2 days, it will give a noticeable difference
1. Connection>more connections settings> disable nearby device settings
2. Location>improve accuracy >disable
A. Wifi scanning
B. Bluetooth scanning .
And enable these 2 options.
A. Adaptive battery
B. Put Unused Apps to Sleep.
4. Long press on each app specially 3rd party(LIKE FACEBOOK, INSTA,YOUTUBE) and rarely used apps and also ON "GOOGLE APP" as well, then click on>app info> then go to these 3 options below on by one
5. Go to settings >apps>search "weather" >click on settings icon right side > change "auto refresh" settings as per your requirements and disable some unnecessary reminder. ( due to auto refresh it continuously consuming battery?)
6. If you use Facebook frequently then disable "auto play video"
Samsung_Support3
Galaxy M
Dear Samsung Member,
To resolve your device battery drain issue please visit this link: https://www.samsung.com/in/support/mobile-devices/samsung-mobile-battery-drain-issue/
For further assistance, register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
Galaxy M
But Screen flickering issue how to solve? Automatically screen light upa and down.
nayankhan97
Galaxy M
Same problem
