Charging connection problem
(Topic created on: 12-02-2023 09:13 AM)
subham47
Galaxy M
In my M51 model When I connect the charger some time its shows fast charging sometime shows superfast charging and sometime it's shows cable charging. Sometimes it's automatically disconnected. Anyone getting this issue.
4 Comments
THAMARAI143
Galaxy M
Same Problem brother
patel_sid
Galaxy M
Yes bro...same issue with my M53
Bhavyanth
Galaxy M
Same issue with my s21FE as well after November security patch.
cs_member10
Galaxy M
Dear Samsung Member,
As per your query, we request you kindly share the log file. Without a log file, we cannot analyze this issue. This will help us to further investigate and resolve this issue.
To attach the log file: Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
