Camera quality issue& network issue
(Topic created on: 4 weeks ago)
chandrasekharsahu
Galaxy M
Camera quality saturation network aggregation problem
3 Comments
goodthings
Galaxy M
Kindly complaint to Samsung customer care support through Samsung Members app as error report also send log files along with this error report for this issue and wait for next update maybe fix it by Samsung team soon. If you like please accept as a solution it's help to other users also, click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
Galaxy M
You're welcome to here.
cs_member10
Galaxy M
Dear Samsung Member,
1. Galaxy device camera issue: ● Kindly check the physical condition of your camera lens, such as broken camera lens or scratchy camera lens.
● Kindly camera lens cleaning: Use a microfiber cloth or a cleaning wipe. Gently remove the fingerprints, dirt, and dust from the camera lens.
● Reset the camera settings: Tap on Camera>Settings>Reset settings>Reset.
● Clear camera application data: Apps>Camera>Storage>Clear Data
2. Galaxy device network issue: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-smartphone-how-to-optimise-network-...
In case the issue still occurs, kindly visit the service centre for a physical inspection of your device. You can locate your nearest service centre with this given link: https://www.samsung.com/in/support/service-center/
