11-11-2024 08:32 AM in
Galaxy M- Mark as New
11-11-2024 08:35 AM in
11-11-2024 09:01 AM in
11-11-2024 09:48 AM in
a month ago in
a month ago in
a month ago (Last edited a month ago ) in
Galaxy MDear Samsung Member,
As per your concern, we want to inform you that it can happen due to glitch. However, kindly perform the following steps to resolve your issue.
● Clear app cache through Device care:
→ Settings > Device care > Storage > CLEAN NOW.
● Reset the device Settings: Settings > General Management > Reset settings>Reset all settings to their default.
