Battery drained problem in M35 5g
(Topic created on: a month ago)
DP145
Galaxy M
6000 mAh battery 🔋 and screen on time is maximum 5 hour?
Is it normal?
What should I do?
Phone is new , 7 months old
13 Comments
goodthings
Galaxy M
Kindly complaint to Samsung customer care support through Samsung Members App as a error report also send log files along with this error report for this issue and wait for next update it's maybe fix it by Samsung team soon. If you like Please accept it's as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
DP145
Galaxy M
Ok
goodthings
Galaxy M
You're welcome.
Krishan15
Galaxy M
DP145
Galaxy M
Good battery backup
Krishan15
Galaxy M
Power saving me use mt kro jyada battery khrab ho jayegi
DP145
Galaxy M
Ok 👍
cs_member10
Galaxy M
Dear Samsung member,
3. Check device network fluctuation. Avoid usage in areas with low network/fluctuation.
9. Update software: Go to Settings > Software update > Download and install > Check for software update > If Software update available > Download > Downloading updates > Install now
10. Reset the device:
IMPORTANT:
• If you do not remember it, then reset (Forgot password) your google account.
• For this:
• Open Gmail (https://accounts.google.com/servicelogin) > forgot password >Select "try another way" > Next > Enter a new password > Next.
If the issue still persists, after performing all troubleshooting steps, would request you to please visit the service center. Below is the link to find nearest service center
http://www.samsung.com/in/support/servicelocation/
DP145
Galaxy M
Okay 👍
Thanks
