β05-20-2021 09:14 AM in
Galaxy M1 Solution
β05-20-2021 12:03 PM (Last edited β05-20-2021 07:32 PM ) in
Galaxy MHowever u can try these steps-
1) Try unistalling apps like phone cleaner becuase they drain alot of battery
2) Try turning of location or GPS
3) If u have any new apps recently, which u think may be causing the problem Unistall it
4) try turning off battery saver, because if u keep it on WITHOUT using it for too long it, maybe causing the battery drain issue.
if u find thid helpful kindly click on the three dots and click accept as solution
β05-20-2021 09:35 AM in
Galaxy M- Mark as New
β05-20-2021 11:43 AM in
β05-20-2021 11:48 AM (Last edited β05-20-2021 11:48 AM ) in
β05-20-2021 09:47 AM in
Galaxy M1. Use mobile in Good Network condition
or, Disable the access to third party apps which is working in background.
or, turn on Wind Down mode before going to sleep
β05-20-2021 10:26 AM in
β05-20-2021 12:28 PM (Last edited β05-20-2021 07:33 PM ) in
Galaxy MSettings > Select Device Maintenance/Device Care > Optimize > Optimize all options like Battery, Storage and Memory
if u find this helpful kindly click on the three dots and click accept as solution
