Resolved! Solved
Battery drain issues
(Topic created on: 03-31-2021 07:20 PM)
yashchaplot
Galaxy M
How to stop this unexpected battery draining app
Ehsank
Galaxy M
If you are only worried for Google play services then its a hub of nany apps under Google which is necessary to run but you can reduce it by
Go to 6 & 7 point nd check carefully
1. Settings>Connection>more connections settings> disable nearby device settings.
2. Settings>>Location>improve accuracy >disable
A. Wifi scanning
B. Bluetooth scanning .
And enable these 2 options.
A. Adaptive battery
B. Put Unused Apps to Sleep.
FOR ANDROID 11;
A. DEVICE CARE > Battery>Background Uses Limit > Put Unused App to Sleep
B. Device care>click on 3dot at top right corner>automation>adaptive power saving
C. Device Care > Battery> More Battery Settings>Adaptive Battery
4. Long press on each app specially 3rd party app(LIKE FACEBOOK, YOUTUBE) and rarely used apps and also ON "GOOGLE APP" as well, then click on>app info(ibutton)>> go to these 3 options below on by one
6.  Go to settings > Google > on device sharing> check which 3rd party apps present there for e.g. if you use paytm , paytm will  shared data to show recommendation and suggestion which also cause battery drain
7.  Go to settings > account and backup> Manage account > check which app syncing automatically there, and if any app which not necessary to auto sync then click on it and "disable sync"
8. Go to settings >apps>search "weather" >click on weather settings (icon)> change "auto refresh" settings as per your requirements and disable some unnecessary reminder. ( due to auto refresh it continuously consuming battery)
10. Settings>Google >click on 3dot at right top corner>usage and diagnostics >off this option.
12 Comments
Ehsank
Galaxy M
A. Wifi scanning
A. Adaptive battery
FOR ANDROID 11;
yashchaplot
Galaxy M
I don't know why but only from last 4 days its consuming 25-30% of battery in a day,
Ehsank
Galaxy M
only since 4 days , did you download any new app or uploading pics on Google photos etc...
yashchaplot
Galaxy M
No
Ehsank
Galaxy M
Open Google photos and check uploading status may be pictures are uploading on Google photos
yashchaplot
Galaxy M
I already checked bro no any pictures or videos are uploading
Ehsank
Galaxy M
Ohk then do those all and observe then
yashchaplot
Galaxy M
Already done, but still consumes battery now it consumes 8%from last charge that is 2 hr ago... no any change in play service...
Ehsank
Galaxy M
See dear don't focus on special one apps specially to Google services check screen on time from 100-1% from battery uses details, that is the main thing
