a month ago (Last edited a month ago ) in
Galaxy M- Mark as New
a month ago in
4 weeks ago in
4 weeks ago in
Galaxy MDear Samsung member,
9. Reset the device:
IMPORTANT:
โข Kindly create data backup of your device via SMART switch mobile application or http://www.samsung.com/in/support/smartswitch pc suite.
โข Remember google password before resetting the device because it is required during initial setup.
โข If you do not remember it, then reset (Forgot password) your google account.
โข For this:
โข Open Gmail (https://accounts.google.com/servicelogin) > forgot password >Select "try another way" > Next > Enter a new password > Next.
Please follow the below steps to reset the device: Settings > General Management > Reset > Temporary cloud backup or External storage backup > tab on Factory data reset (This will erase all data, including files and downloaded apps)
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send).
2 weeks ago in
Wednesday in
Galaxy M2. Reduce screen brightness.
3. Adjust display refresh rate to standard mode.
4. Turn off connectivity.
Disable Wi-Fi, GPS, and Bluetooth when not in use.
5. Turn off AOD.
If you like this solution.
Please
Accept as a solution .
Wednesday in
Galaxy Mor
Put in deep sleeping which apps not in regular usage.
2. Uninstall extra apps
3. Battery optimization.
4. Closed all background applications
Please
