09-24-2025 09:24 AM in
Galaxy MSolved! Go to Solution.
2 Solutions
09-24-2025 09:45 AM in
Galaxy MOpen Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.
If you find this helpful, I'd appreciate it if you could ACCEPT it as a SOLUTION. Thank you 😊
09-24-2025 06:14 PM in
Galaxy M- Mark as New
09-24-2025 11:30 AM in
09-25-2025 09:01 AM in
Galaxy MDear Samsung member,
3. Check device network fluctuation. Avoid usage in areas with low network/fluctuation.
9. Update software: Go to Settings > Software update > Download and install > Check for software update > If Software update available > Download > Downloading updates > Install now
10. Reset the device:
IMPORTANT:
• If you do not remember it, then reset (Forgot password) your google account.
• For this:
If the issue still persists, after performing all troubleshooting steps, would request you to please visit the service center. Below is the link to find nearest service center
http://www.samsung.com/in/support/servicelocation/
10-02-2025 01:35 PM in
10-02-2025 02:28 PM in
10-02-2025 01:39 PM in
Galaxy M
