Resolved! Solved
Battery drain issue in samsung galaxy m35
(Topic created on: 09-29-2024 07:14 PM)
Wondervicky
Galaxy M
Battery is draining too fast I don't know why please help with the issue for 1hour it drains 10% of charge foe normal usage
Resolved!
13 Comments
Abpal
Galaxy M
No tips! Just enjoy your phone in your way 😂. You already have good battery life even on 5g.
Wondervicky
Galaxy M
Is it really an good battery life I thought it was bad sorry.
Wondervicky
Galaxy M
Thanks for saying ❤🔥🔥🔥🔥
cs_member8
Galaxy M
Dear Samsung Member,
As per your concern, we would request you kindly perform the following steps to resolve your issue by the given links.
Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
You can reset your device by following the steps.
