Resolved! Solved
Battery drain issue in samsung galaxy m35
(Topic created on: 09-29-2024 07:14 PM)
Wondervicky
Galaxy M
Battery is draining too fast I don't know why please help with the issue for 1hour it drains 10% of charge foe normal usage
goodthings
Galaxy M
Kindly complaint to Samsung customer support through Samsung Members App as error report also send log files Along with this error report for this issue and wait for next update may be fix it by Samsung team soon. If you like please accept as a solution it's help to others users also,click on 3dots in my reply section and click on accept solution. Thanks.
13 Comments
goodthings
Galaxy M
goodthings
Galaxy M
Your's most welcome to here.
Abpal
Galaxy M
What is the screen on time of your phone ?
Wondervicky
Galaxy M
Battery usage-51%
Screen on time -4hours51minute
Screen off time- 14hours 17 minute
Abpal
Galaxy M
Then, why are you even complaining ? You are getting such a great battery life.
If you are still in doubt you can check with youtube reviews of the same device.
Abpal
Galaxy M
By the way, you are using 5g right ?
Wondervicky
Galaxy M
Yes
Abpal
Galaxy M
Then, your battery life is good. And, it cannot be improved further without disabling some important features like location, bluetooth, sync, etc..
Wondervicky
Galaxy M
Can you give any tips
