10-08-2025 01:32 PM in
Galaxy M- Mark as New
10-08-2025 01:37 PM in
10-08-2025 01:43 PM in
10-09-2025 09:27 AM in
Galaxy Mबैटरी बहुत जल्द डिस्चार्ज हो रहा है हिटिंग और फोन हैंग भी हो रहा है
10-09-2025 10:04 AM in
10-09-2025 12:34 PM in
Galaxy MDear Samsung member,
3. Check device network fluctuation. Avoid usage in areas with low network/fluctuation.
9. Update software: Go to Settings > Software update > Download and install > Check for software update > If Software update available > Download > Downloading updates > Install now
10. Reset the device:
IMPORTANT:
• If you do not remember it, then reset (Forgot password) your google account.
• For this:
If the issue still persists, after performing all troubleshooting steps, would request you to please visit the service center. Below is the link to find nearest service center
http://www.samsung.com/in/support/servicelocation/
