11-26-2024 11:38 PM in
Galaxy M- Mark as New
11-27-2024 07:40 AM in
11-27-2024 09:03 AM (Last edited 11-27-2024 09:09 AM ) in
Galaxy MLowering refresh rate
Turn off background finally lowering the phone feature making it underperform, then what is the purpose of phone upgrade? These steps recommended under topic "old Android phone battery drain fix" .you recomend it for a new phone that was spoiled by samsung update. If you are a m35 user raise the complaint please
11-27-2024 09:04 AM in
11-27-2024 09:12 AM in
11-27-2024 09:14 AM in
11-27-2024 09:07 AM in
Galaxy MDear Samsung Member,
As per your concern, we would request you kindly perform the following steps to resolve your issue by the given links. We are taking your valuable feedback regarding Battery drain issue.
● Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
→ Update the software if available: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-smartphone-how-to-update-software/
→ You can reset your device by following the steps.
In case the issue still occurs, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send).
11-27-2024 09:16 AM in
11-29-2024 05:44 PM in
11-29-2024 09:21 PM in
Galaxy M
