Battery drain M14
(Topic created on: 09-18-2025 08:55 AM)
sanjit859
Galaxy M
Bhai yar August ka security patch update krne se M14 5G ka battery drain issue bahut ho rha hai kya karu??
3 Comments
IndianPaul
Galaxy M
Run app booster fine lock module & dail *#9900# then click delete logcat/dumpcat files. Make sure that auto blocker is turned off
sanjit859
Galaxy M
Fine lock not supported 🙏
cs_member10
Galaxy M
Dear Samsung member,
9. Reset the device:
IMPORTANT:
• For this:
• Open Gmail (https://accounts.google.com/servicelogin) > forgot password >Select ""try another way"" > Next > Enter a new password > Next.
Please follow the below steps to reset the device: Settings > General Management > Reset > Temporary cloud backup or External storage backup > tab on Factory data reset (This will erase all data, including files and downloaded apps)
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send).
