08-24-2024 09:48 AM in
Galaxy M- Mark as New
08-24-2024 11:55 AM in
08-24-2024 03:34 PM in
08-24-2024 06:00 PM in
Galaxy MDear Samsung Member,
As per your concern, we would request you kindly perform the following steps to resolve your issue by the given links.
Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
You can reset your device by following the steps.
