Highlighted
M31S -6000 mah battery and not giving 1 day battery backup. Samsung please lookup the issue. The charging is also gets slow
9 Comments
Highlighted
yes bro wait for update most of m series have battery draining issue but below step to consume battery
Your device provides various options that help you conserve battery power.
• Optimise the device using the device care feature.
• When you are not using the device, turn off the screen by pressing the Side key.
• Activate power saving mode.
• Close unnecessary apps.
• Deactivate the Bluetooth feature when not in use.
• Deactivate auto-syncing of apps that need to be synced.
• Decrease the backlight time.
• Decrease the screen brightness
Highlighted
I have done probably all the options that you have mentioned. but still its not getting last for 24 hours. I am facing this problem from last couple of days. Infact the charging also got slowed down. initially it took 2 hours to complete charge. now it's taking 3 hours plus
Highlighted
ok brother send feedback to samsung wait for next update brother
Highlighted
yes , i am also facing the same problem !
Highlighted
disable google app. if you want to search something, search it on chrome. google consumes too much battery. im getting 11 hours SOT with 20% battery left. see screenshot.
Highlighted
Dear Samsung Member,
To resolve your device battery drain issue please visit this link: https://www.samsung.com/in/support/mobile-devices/samsung-mobile-battery-drain-issue/
For further assistance, register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
Highlighted
Guys one good news. Yesterday I got an update. Since then the battery Drain problem got slower. It's now getting better
Highlighted
i am also suffer very fast battery drain problem
Highlighted
You will get an update and this problem will get sorted
