01-05-2025 12:56 PM in
Galaxy M- Mark as New
01-05-2025 04:16 PM in
01-05-2025 05:32 PM (Last edited 01-06-2025 12:58 PM ) in
Galaxy MDear Samsung Member,
● Check app cache: Settings > Device care > Storage > CLEAN NOW.
● Reset the device Settings: Settings > General Management > Reset settings>Reset all settings to their default.
● Kindly Enable/ disable Adaptive brightness option once.
Path: Settings app> Display >then tap the Adaptive brightness switch to activate it/ deactivate it.
● Smart view clear data: Settings> Apps> Filter and sort> Show system apps>OK>Smart View app> Storage> Clear data.
● Make sure your Tv voluam is working fine.
● Kindly try to connect the same after performing the above given steps.
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send.)
