someone give me solution for heavy battery drain for my j6 after pie update
(Topic created on: 06-15-2019 06:19 PM)
Milind06
Galaxy J
After reaching out the service center also still j6 has a lot of battery drain issue..plus help me out guys any tips..or solutions will be accepted
15 Comments
viswajit
Galaxy J
🤣🤣 it's not proper suggestion.
ashu225
Galaxy J
wait for fota update
SumanDhar
Galaxy J
i am suggesting you a best thing....go to recovery mode and clear all your caches and keep your night mode always on...don't keep your mobile data on always that drains most of your battery use it only according to urs requirement...try to use wifi(if possible)may Samsung fix it in next update....and truly i am saying i am not facing a such worst issue bcz usually i get a day of battery life...with remaining 25% at the end of the day..in oreo i usall get 1.5 days
Rajneeshydv
Galaxy J
Make sure put app to sleep turn on for all the apps
SumanDhar
Galaxy J
DrPeter
Galaxy J
put every app to sleeping mode.
turn off mobile data, GPS , location,wifi, AOD, while not in use.
disable unused apps.
go to permission monitor and deny unwanted permission of apps.
