nishantsoni
01-19-2018 01:24 PM in
Galaxy J
after the last update battery is draining very fast and charging very slow plz fix this isuue i am facing hige problem with this kind of problem #fixissue #samsung #battery #batterydrainage
6 Comments
kdss
01-19-2018 02:17 PM in
Galaxy J
please suggest
s01gautam
01-19-2018 03:45 PM in
Galaxy J
https://play.google.com/store/apps/details?id=com.application.onead&hl=en Your friend has invited you to try OneAD app. OneAD is Refer and Earn + Shop and Save mobile app. Install this free app become a member and earn up to 2.5 Lakh Rs per month. Your referral code for registration is reffer code -"M1EQFP"
admin_
01-19-2018 06:35 PM in
Galaxy J
Thank you for Joining Samsung community. We would recommend taking some troubleshooting steps to further isolate what you may be experiencing. Find troubleshooting steps on provided link http://www.samsung.com/in/support/skp/faq/1101689. Please let the community know what steps you have taken and if you have noticed any changes or improvements. This will help the Community to provide you steps without repeating any steps you may have already taken.
Be sure to hit ♡ when you find an answer that works for you. For Further assistance, you can get in touch with us via Live Chat option by following- http://livechat.support.samsung.com/Customer_new/IN. You can also connect us via Samsung Members web community by following mentioned url-https://community.samsungmembers.com/en_IN#/
CoolAkki
01-23-2018 10:07 AM in
Galaxy J
how too us my battery long time
nishantsoni
01-23-2018 10:34 AM in
Galaxy J
i have checked all the checklist but nothing happened
harriya
05-31-2018 03:53 PM in
Galaxy J
Solution1:-uninstall (clear data first,then uninstall)and force stop(clear cache first then force stop) unused and unusual apps, clear caches, clear RAM, optimizing battery by putting apps sleep, force stop or disable unused useless preloaded apps...samsung apps,Microsoft apps and Google apps like chrome as it consumes more Ram and background data which results in heavy battery drain,,instead use browser, browser will take less Ram..(eg..via browser under 500KB)..clear or delete useless folder or duplicate folder in file manager... don't install apps from other stores and sites, it will cause your phone damage ..if you install these apps then uninstall it.....Solution2:- change your data cable(good quality wire) do all these things atleast once a day for best results....apne phone ko update maat karo jab aapka phone thik chal raha h to... update karne se phele 1 mahina ruko or dekho logo ke reviews update ke bare me agar thik hai to.... phir update karo...nonstop phone use karne se bhi problem aati hai isliye phone ko 2..3 din minimum use karo....
