When and how my camera issue will be solved by u
(Topic created on: 08-16-2017 12:39 PM)
arjunkumar901
Galaxy J
When and how my camera issue will be solved by u in j7 max phone
kindly tell me how it will get resolved by replacing the phone by Samsung or by any other methods bedb3cf5-60c9-484e-9595-a2e57fd08751.jpg
admin_
Galaxy J
"Thank you for sharing your concern. Let me recommend some steps to further isolate and determine what you are experiencing. Please be aware that device speeds may vary based on multiple outside factors.
1) Check the Picture size (Camera Capacity) in camera setting (It should be Max according to Camera Capacity)
2) Turn on the Auto Flash (If Available in the Device)
3) Reset the Camera (From the Camera Setting)
4) Software update via FOTA,Kies or SMART Tool".
