Resolved! Solved
J7PRIME2 battery problem please solve
(Topic created on: 10-16-2019 06:12 PM)
earntube
Galaxy J
Kaya karu vai?
kabirraihan
Galaxy J
Discharge your phone's battery at 0% then turn off phone and charge phone battery upto 100%. Then open your phone. It's called battery calibrate
3 Comments
kabirraihan
Galaxy J
Not applicable
Galaxy J
yes it's only the solution...and you can turn those app to sleep mood which can perform background run eligibility
Galaxy J
checkout my members profile for tips to extend the life span of your battery.
