12-30-2021 01:58 PM in
Galaxy J- Mark as New
12-30-2021 02:08 PM in
12-30-2021 03:16 PM in
Galaxy Jwhatsapp - whatsapp media
Then move the contents of whatsapp folder to the memory (if you do so, you will not be able to view the medis in the whatsapp. You must open via gallery or by any file explorer app (X PLORE).
01-03-2022 07:23 PM in
Galaxy JDear Samsung member,
Check space availability:
Is there sufficient space available on your device?
Kindly check the space on your device:
Path: Settings > Device Care >Storage
To improve the device performance there should be sufficient space. Request you to keep at least a ''minimum 20% internal memory free''.
Kindly check RAM in your device:-
Path: Settings>Device care>Memory.
To improve the performance RAM of the device should be free. So, clear the RAM memory once a day.
Check app cache
Does the device hang while accessing any particular Application/Game etc?
Please follow the below steps
1- Clear app cache through Device care:
Step1: Navigate to the app's screen and tap on Settings.
Step2: Tap on Device care.
Step3: Tap on Storage.
Step4: Tap on CLEAN NOW.
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Ask question).
Warm regard,
