Robs23
10-16-2019 10:46 AM in
Galaxy J
Hello,
After last security patch file update on J6, device is working slow and hanging issue is still not resolved... Battery draining is as high as before.. Can't bare this issue with device....
So poor support & solutions from care system.....
2 Comments
Not applicable
10-16-2019 11:48 AM in
Galaxy J
For resolving the hanging issue, you'll need to free up some space/storage on your device and as far as battery draining issue is concerned, try setting the brightness level to low. Hope it helps.
Robs23
10-16-2019 11:53 AM in
Galaxy J
Done all of them.. Not satisfied with solutions & update
