Resolved! Solved
Any body help me
(Topic created on: 10-06-2021 11:23 AM)
adminkiller
Galaxy J
The problem 😕
The battery saver and data saver icon not showing
4 Solutions
ARJUNB
Galaxy J
Watching this accessibility sign is troubling me. Plz go to your setting in accessibility option and check if u have tongle anything there. Screenshot_20211006-114440_Samsung Members_46059.jpg
Galaxy J
Turn off data saver and turn off data warning
Galaxy J
Yes, it will not show when you swipe up and exit notification panel.
It is not a bug.
Galaxy J
Data save icon won't show when you're not on quick panel
Is goodlock supported?
Is so then use quickstar
13 Comments
ARJUNB
Galaxy J
Have u tried turning it back on and off
adminkiller
Galaxy J
Tell me how to do it
ARJUNB
Galaxy J
Drop your notification panel down. U will see power saving option tap on it ones if it is on or off. The do it again. To on it. And check Screenshot_20211006-113713_Samsung Members_46057.jpg
adminkiller
Galaxy J
I already do it not working 😕
ARJUNB
Galaxy J
Which phone r u using
ARJUNB
Galaxy J
Galaxy J
ARJUNB
Galaxy J
His problem is, that the icon has disappeared but if pulling down the notification panel it shows.
Galaxy J
It is not a bug.
