Saqibjkl555
07-31-2024 12:20 AM in
Galaxy Fold
Samsung Z Fold 5 users,
Have you'll noticed the battery drain after the new update????
6 Comments
RISKYTAP
07-31-2024 03:49 AM in
Galaxy Fold
Dear reader,
I would like to inquire if you have observed any changes in the battery usage data of your device after the recent update. Specifically, I am interested in knowing the difference in the battery drain time between the information available before the update and the information available after the update.
I understand that many of us are curious about this matter, and I would appreciate it if you could share your observations. If you have noticed a significant difference in battery drain time between the two periods (before and after the update), please let us know.
Thank you for your attention to this matter.
Best regards,
Best regards,
RISKYTAP
07-31-2024 03:50 AM in
Galaxy Fold
If there is someone who is able to provide assistance, they will certainly extend their support to you. 🙂
AkashMadusanka
07-31-2024 06:08 AM in
Galaxy Fold
That's not a big deal, bro... Try to update your apps, which have updates. 😊
If my comment is helpful to you in any way, consider to select the Accept Solution by clicking on the 3 dots of the comment.
Thank you ☺️
Thank you ☺️
Saqibjkl555
07-31-2024 06:10 AM in
Galaxy Fold
Apps all updated to the point
But i see a very unusual drain
Anyways
I'll wait for the next update
That should fix it
Anyways
That should fix it
RISKYTAP
07-31-2024 09:18 AM in
Galaxy Fold
😕 There's another way if confirming if you confused about what happened to the device
I have already added to comments About it
07-31-2024 08:34 AM in
Galaxy Fold
Upgrading the android OS can cause issues with battery life. First try restarting your device, this alone may resolve some apps that are draining a lot of battery in the background. You can also try booting into recovery mode and clearing the cache partition. There is also a Good Guardian Module called Galaxy App booster that will optimize apps that will streamline them with the os upgrade.
If none of them work, please back up ur data and factory reset your device. This is your last resort.
Hope this helps! If my comment helped you in any way, please consider hitting the 3 dot menu and accepting it as a solution. It helps me. Thank you!
