Samsung galaxy f34 battery drain
(Topic created on: 11-17-2024 04:13 PM)
vishalshiv1
Galaxy F
Samsung provide 6000mah battery for better battery life but samsung make us fool .The battery so called 6000mah drain fast like rocket . I buy this samsung f34 for bigger battery after buying I thought next update it will be fixed but there is no any response. My life worst thing to buy samsung for better battery.
Do something samsung to your battery
And provide update for battery
I buy this 5 month ago and my experience is very bad for your product. Do something
5 Comments
goodthings
Galaxy F
goodthings
Galaxy F
Your's most welcome to here.
cs_member10
Galaxy F
Dear Samsung Member,
As per your concern, we want to inform you that the usage varies significantly across different applications. Some apps consume more battery depending on factors such as screen time, network fluctuations, and refresh rates. We are taking your valuable feedback this. Kindly perform the following steps to resolve your issue by using the given links.
● Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
→ Update the software if available: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-smartphone-how-to-update-software/
→ You can reset your device by following the steps.
If the issue still occurs, please visit the service centre for a physical inspection of your device. You can locate your nearest service centre with this given link: https://www.samsung.com/in/support/service-center/
vishalshiv1
Galaxy F
Dear sir can you have information for any battery related update ,I do everything thing that you mentioned above but there is no any improvement
kundankrmahto
Galaxy F
I stand with you dear
Samsung makes us Fool
Samsung provide us solution
Off Wifi
Off Data
Off Location
Off Bluetooth
I mean this is ridiculous
We bought a Phone not A Box
