Issue With Power Button Or Finger Print Senior
(Topic created on: 09-25-2024 07:31 PM)
Aero-Star-Educator
Galaxy F
FingerPrint Sensor is not Working Properly
Anyone Know How to fix it ?
Please Suggest Any Solution.
Samsung f23 5g
4 Comments
JD__
Galaxy F
You might probably need to reset the fingerprint data and try again with fresh one, if the problem still continues... I think the sensor got broken/something faulty occurred
goodthings
Galaxy F
Kindly reset factory data with backup then try to it's again. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
Galaxy F
Your's most welcome to here.
cs_member10
Galaxy F
Dear Samsung Member,
Ensure that your fingers are clean and dry.
Note: If the skin on your fingertips is peeling or cracking, or your fingerprint is difficult to capture, the fingerprint ID on your phone may not work.
If your fingerprints fail to unlock the phone while the phone is recharging, remove it from the charger and try again. If you are charging the phone with a charger and data cable from other brands when you use fingerprints to unlock the phone, they may interfere with the fingerprint sensor and cause the recognition to fail.
Clean the fingerprint sensor with a soft cloth. Make sure the fingerprint sensor is dry and free from any debris that may cause the sensor to be unable to recognize the fingerprint.
Remove the current fingerprint and set up the fingerprint again. When you touch the sensor to set up a fingerprint, make sure you set the entire fingerprint, including the outer area of your fingertip. Setting the entire fingerprint area enables successful fingerprint recognition with any grip.
How to remove Fingerprint: Path: Settings> Biometrics and Security> Fingerprints> Fingerprint1> Remove> Remove again to confirm.
How to Set up Fingerprint: Path: Settings>Biometrics and Security> Fingerprints> Fingerprint> Scan your fingerprint> Place your finger on the sensor, then lift it off when you feel a vibration> Continue> Reposition your finger each time to capture the edge of your fingerprint> Done> Fingerprint added successfully.
Try Safe mode: https://www.samsung.com/in/support/mobile-devices/safe-mode-on-samsung-phones/?srsltid=AfmBOooat1Wm0...
You can reset your device by following the steps.
If the issue still occurs, please visit the service centre for a physical inspection of your device. You can locate your nearest service centre with this given link: https://www.samsung.com/in/support/service-center/
