12-16-2021 07:31 PM in
Galaxy F
12-16-2021 07:38 PM in
Galaxy F1. Settings>Connection>more connections settings> disable nearby device settings.
2. Settings>>Location>improve accuracy >disable
A. Wifi scanning
B. Bluetooth scanning .
And enable these 2 options.
A. Adaptive battery
B. Put Unused Apps to Sleep.
FOR ANDROID 11;
A. DEVICE CARE > Battery>Background Uses Limit > Put Unused App to Sleep
B. Device care>click on 3dot at top right corner>automation>adaptive power saving
C. Device Care > Battery> More Battery Settings>Adaptive Battery
4. Long press on each app specially 3rd party app(LIKE FACEBOOK, YOUTUBE) and rarely used apps and also ON "GOOGLE APP" as well, then click on>app info(ibutton)>> go to these 3 options below on by one
6. Go to settings > Google > on device sharing> check which 3rd party apps present there for e.g. if you use paytm , paytm will shared data to show recommendation and suggestion which also cause battery drain
7. Go to settings > account and backup> Manage account > check which app syncing automatically there, and if any app which not necessary to auto sync then click on it and "disable sync"
8. Go to settings >apps>search "weather" >click on weather settings (icon)> change "auto refresh" settings as per your requirements and disable some unnecessary reminder. ( due to auto refresh it continuously consuming battery)
10. Settings>Google >click on 3dot at right top corner>usage and diagnostics >off this option.
Credit-Ehsank
12-16-2021 08:00 PM in
Galaxy FI get around 9 to 11 hours of sot on my F62 with proper maintenance and no gameplay..
12-16-2021 08:09 PM in
Galaxy FAlso I get 9 to 11 hour
12-16-2021 08:18 PM in
Galaxy F- Mark as New
12-16-2021 08:55 PM in
Galaxy FU have to think about software optimization which is lacking
12-16-2021 08:58 PM (Last edited 12-16-2021 08:58 PM ) in
12-17-2021 12:02 AM in
12-17-2021 01:17 AM in
Galaxy F
