DISPLAY PROBLEM PLS HELP
(Topic created on: 09-22-2024 08:48 AM)
unknown071
Galaxy F
My phone lcd display has this issue as u can see here and my device never fell or damaged. Its also having ghost touches. Pls guide me with this issue
5 Comments
Ak_Rocks
Galaxy F
Your display board Backlight is cooked go replace it these are problems with LCD displays!
unknown071
Galaxy F
Ok
cs_member10
Galaxy F
Dear Samsung member,
As per your query, kindly follow the easy troubleshooting steps which might help to solve the issue.
Kindly restart your device once: To power off through Quick settings, swipe down from the top of the screen. Tap the Power icon in the upper right of the screen (next to the Settings icon), and then tap Power off.
Update device software (If Software update available): https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-smartphone-how-to-update-software/
You can reset your device by following the steps.
Samsung Customer Support.
abhinavkrpcse
Galaxy F
Display change is required in service center.
arusha1234
Galaxy F
Display replacement is the only solution.
