4 weeks ago (Last edited 4 weeks ago ) in
Galaxy F- Mark as New
4 weeks ago in
4 weeks ago in
4 weeks ago in
4 weeks ago in
4 weeks ago in
Galaxy FDear Samsung Member,
As per your concern, we would request you kindly perform the following steps to resolve your issue by the given links. However, we are taking your valuable feedback regarding this.
● Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open the Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select Error report > select the appropriate issue category> Type your query and send).
4 weeks ago in
Galaxy F
