11-07-2024 11:05 PM (Last edited 11-07-2024 11:06 PM ) in
Galaxy F- Mark as New
11-07-2024 11:55 PM in
11-08-2024 12:07 AM in
Galaxy FTop 3 dot
Reset apps preference
Now restart device
11-08-2024 07:58 AM in
11-08-2024 09:21 AM in
Galaxy FDear Samsung Member,
As per your concern, we would request you to kindly perform the following steps to resolve your issue by using the given links.
1. Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
2. Galaxy device heating issue: https://www.samsung.com/in/support/mobile-devices/why-the-device-heats-up-during-use/
3. Galaxy device UI lag issue: https://www.samsung.com/in/support/mobile-devices/why-is-my-phone-slowing-down-and-how-can-i-speed-i...
→ Kindly uninstall that application by following the below steps and check once as the issue might occur due to third-party applications: Settings> Apps> Select the third-party application from Apps> Uninstall.
→ Kindly check if you are using a memory card on your device.
If you are using the memory card on your device. we will advise you to safely remove it from your device. For this follow the below steps:
→ Step 1: Before removing the memory card, first, unmount it for safe removal.
On the Home screen, tap Apps > Settings > Device maintenance > Storage > More option > Storage settings > SD card > Unmount. Insert the ejection pin into the hole on the tray to loosen the tray.
Note: Ensure that the ejection pin is perpendicular to the hole. Otherwise, the device may be damaged.
Step 2: Pull out the tray gently from the tray slot.
Step 3: Remove the memory card.
Step4: Insert the tray back into the tray slot
Note: Please ensure that the memory card is not removed while the device is transferring or accessing information. Doing so can cause data to be lost or corrupted or damage to the memory card or device.
Samsung is not responsible for losses that result from the misuse of damaged memory cards, including the loss of data.
→ Remove third-party accessories: Due to ''3rd Party'' (Not provided by Samsung) Accessories, (Like ''Chargers, USB Cables'' etc.) device might also hang. So kindly avoid the usage of these 3rd party accessories.
→ If you enabled Power Saving Mode, Power saving mode limits the performance of the device. So we recommend disabling the Power Saving mode in your device.
● Update device software (If available): Settings > Software update > Download and install > Checking for software update > Software update available > Download > Downloading updates > Install now.
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send.)
