Aunimesh
10-10-2022 08:30 PM in
Galaxy F
After The update, My phone's battery backup has gradually degrade, before update it used to give around 12-14 hrs of battery backup. But after the update it has reduced to only 5-6 hours.
#Samsung team please look into it and try to fix the problem
Also the camera has downgraded very badly.
#Samsung #Galaxy #Galaxy F62 #F62 #Battery drainage
5 Comments
TamaghnaMajumde r
10-10-2022 09:13 PM in
Galaxy F
Same issue from last 3-4 months
RatulKumarDey
10-10-2022 09:52 PM in
Galaxy F
Same issue with my device also from last software update
Ajay_das
10-10-2022 11:38 PM in
Galaxy F
Same issue every one facing same problem
deepcat89
10-11-2022 02:45 PM in
Galaxy F
I'm using F62 for a year now.
No issues at all. Phone performance is good as new.
Reason and solution :
I never updated my phone since I bought. Still using on android 11 .
Never update phones , generally there will be bugs in updates which will cripple devices.
Next time never update phone if it's stable and gives good performance.
Why fix if isn't broken ?
Aunimesh
10-14-2022 08:19 PM in
Galaxy F
Beacause you get more features. And I would say after update My phone has gotten smoother, eveything is working like a charm. Even Goodlock works properly after update, and simply have fallen in love with One UI 4. Just this Battery Issue.
