Battery Drain issue after recent Update
(Topic created on: 11-30-2024 08:21 PM)
XGSK
Galaxy F
Hi Team, after recent update I am facing batter drain issue. I have gone through previous comments and workaround for similar issue, but after following few workarounds still facing battery drain issue.
Request to help
6 Comments
Wodehouse
Expert Level 4
Galaxy F
Which phone ?
XGSK
Galaxy F
F62
Wodehouse
Expert Level 4
Galaxy F
The battery drain issue on your Samsung Galaxy F62 after the recent update is concerning. Since you've already tried some workarounds, let's dive deeper to identify the root cause and explore additional solutions:
*Identify Battery-Draining Apps*
1. Go to _Settings_ > _Battery and device care_ > _Battery_.
2. Look for apps consuming excessive battery power.
3. Uninstall or restrict background usage for unnecessary apps.
*Additional Troubleshooting Steps*
1. *Disable Bluetooth and Wi-Fi when not in use*: Go to _Settings_ > _Connections_.
2. *Turn off Location services*: Go to _Settings_ > _Connections_ > _Location_.
3. *Reduce Screen Brightness and Timeout*: Go to _Settings_ > _Display_.
4. *Turn off Always-on Display*: Go to _Settings_ > _Display_ > _Always-on display_.
5. *Reset Network Settings*: Go to _Settings_ > _General management_ > _Reset_ > _Reset network settings_.
6. *Clear System Cache*: Go to _Settings_ > _Battery and device care_ > _Storage_ > _Internal storage_ > _Clear system cache_.
*Advanced Troubleshooting*
1. *Boot your device in Safe Mode*: Press and hold the _Power button_ until your device restarts. Release the _Power button_ and immediately hold the _Volume down button_. If the issue persists in Safe Mode, it could indicate a software issue.
2. *Perform a Factory Reset*: Go to _Settings_ > _General management_ > _Reset_ > _Factory data reset_. This will erase all data, so be sure to back up your important files and data.
If none of these steps resolve the issue, consider visiting a Samsung authorized service center or contacting their customer support for further assistance.
If this reply answered your query please mark my reply as "resolved" by clicking 3 vertical dots on top right of my reply. Thank you 😊
goodthings
Galaxy F
goodthings
Galaxy F
Your's most welcome to here.
cs_member10
Galaxy F
Dear Samsung Member,
As per your concern, we would request you kindly perform the following steps to resolve your issue by the given links.
● Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
→ You can reset your device by following the steps.
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send.)
