12-27-2018 04:22 PM in
Galaxy C- Mark as New
12-27-2018 04:26 PM in
12-27-2018 04:38 PM in
12-27-2018 04:57 PM in
12-31-2018 06:51 PM in
12-29-2018 03:07 PM in
12-29-2018 03:42 PM in
Galaxy C1 Adjust the brightness of the device then check (Setting-->Display-->Brightness)
2 ""Disable the “Show Screen Updates"" option in developer options or completely disable the Developer options.""{(Setting-->Developer options (If its available & highlighted)-->Show Screen Updates)}
3 Check third party applications if downloaded recently. Post which check in Safe Mode, if the issue still persists.
4 If the device is in Safe mode and the problem still exists, we would advise you to create the Data backup & Factory Reset the device.
5 Periodic Software Update through FOTA, SMART SWITCH or Smart Tool is intended to resolve the issue as well.
Be sure to hit ♡ when you find an answer that works for you. For further assistance, you can get in touch with us via Live Chat option by following- http://livechat.support.samsung.com/Customer_new/IN. You can also connect us via Samsung Members web community by following mentioned url-https://community.samsungmembers.com/en_IN#/
01-13-2019 08:46 AM in
07-06-2019 07:45 PM in
Galaxy Cgreat post
