Highlighted
are bhai...tu...care pe jkr..software update karwa le...
Highlighted
"The issue which has occurred in your device requires binary updates and the same is already escalated to R&D team for rectification. Soon you will get binary update for the same via FOTA. i.e.
Menu> Settings> Software Update> Auto Update> Enable it."
Highlighted
fast charger adopter is not working 6month go m buy the c9 pro and the problem in this
what can I do.
Highlighted
nothing you have to buy a separate one by your own money
