slow charging, highly heating while charging, battery drain
(Topic created on: 07-12-2020 09:06 PM)
Samsung_NHAjFCv
Hi I am facing some issues in my mobile Samsung a50 after updated to June security patch.after updated my phone charging speed gets slow and getting so must of heat while charging also battery drain faster plzz fix the problem
6 Comments
Lakshman24
clean the system junk files... use apus security app install in play store.. its stops the running back ground apps
I get this issue after updating my phone
Lakshman24
yes same prblm. here after upgrade android 10 phne charging issue i mean charging speed gets slow and drain fast
msn678
yes i have same issue battery faster drain.samsung big flop on their update
AlblalyA50
We hope to get a new update to fix these problems
cs-member13
Expert Level 4
Dear Samsung Member,
We apologize for the inconvenience caused to you. We would request you to kindly raise your concern under the Ask Question section from Samsung Member Application with more details, so that we can help you out with this.
Samsung Member Application > click on get help > send feedback > Ask Question.
