Highlighted
Quick battery drain and heating on my galaxy a50. How to solve this issue?
13 Comments
Highlighted
Expert Level 3
send feedback brother to Samsung
Highlighted
Expert Level 3
they will solve the issue by security patch
Highlighted
regarding battery issue u can do these settings to save more battery life
1. Connection>more connections settings> disable nearby device settings
2. Location>improve accuracy >disable
A. Wifi scanning
B. Bluetooth scanning .
3. Google >click on 3dot>usage and diagnostics >off this option
4. developer option >background limit>no background processes.
5. Long press on each app specially 3rd party and rarely used app>app info>
6. Device care>battery >select "optimised and adaptive power saving.
Steps to enable developer option
settings >about phone>software information >then u find build number >tap 7 times>then back to settings
and at end of settings one new option called developer option
click on it and find that option
Highlighted
then go to settings >apps>search Google >notifications >and disable all unnecessary notification as Google has huge notifications settings which consuming lots of battery you can see in the image
Highlighted
you can remove your backcover it will reduce your phone temperature and this will save your battery and please mark this as solution if you get some help by clicking on 3 dots.
Highlighted
and regarding heating , may I know at what time ur mobile getting heat?
like during charge
or while playing games?
Highlighted
during charge
Highlighted
during charge is sometimes acceptable, but as of now if you feel over heated then switch of for few minutes or charge at flight mode
and wait for next update
and the same time send feedback to Samsung by using get help section
Highlighted
Yes bro m series and a series have issue after july update heating and battry drain please wait for next update and also send feedback to samsung via member app
