<Battery problems solution>
(Topic created on: 11-24-2023 12:36 PM)
ABS227
1-enable protect battery option
It stops charging at 84-85.
2-dont use fast charging option when there is no need.
Because it increase pressure on phone's battery.
3-dont use your phone below 15% battery remaining.
4-refresh your battery status by following below tutorial👇
dial*#9900# on your phone dialer
SysDump will open
Scroll down
Select battery stats reset option
and then click on exit.
3 Comments
HasanAskari
Don't reset battery status as it may disturb the battery sync algorithm. Choice is your bro.
SAHASamsung
Beginner Level 3
Hassan bhai, could you pls guide. My Galaxy Ultra is giving me battery time of 9 hrs. No game and battery saver option on.
Do I need to replace the battery. I have purchased 2nd hand
ShahzadRaza
Salam bhai
